Front leaf spring size
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by TONYP, Oct 16, 2002.
  1. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    Will a set of front leaf from a 1977 K5 chevy fit on a 1972 K5 /forums/images/graemlins/1zhelp.gif
    <font color="red">LETS GO ANGELS!! </font color>
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    easy answer...NO.
    They are 3" longer then a stock leaf.
    But that is what I am going to do when I remove the stiff as hell rancho's that I have in the front. Just a bit of "tweaking" required.
  3. florida4x4
    florida4x4 1/2 ton status
    Sep 9, 2002
    255
    Florida
    yes they will fit. You need a smoke wrench to move the front pearches forward and stick welder to put em back on the frame. ez.
  4. TONYP
    Aug 13, 2002
    2,116
    so cal
    So you moved the front mount forward 3"...how is the ride...softer...don't really want to reposition the mount, could you fab up some new mount hanger a bolt it on. I going to have a look ....then the next question is did you have to put some kind of traction bar on for spring wrap...I'm trying some ideals on that right now....
    /forums/images/graemlins/angryfire.gif <font color="red"> LETS GO ANGELS </font color> /forums/images/graemlins/angryfire.gif
  5. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    You get them re-arched so the eye to eye length is right. But they'd be real high. /forums/images/graemlins/grin.gif
  6. BigMac
    BigMac 1/2 ton status
    May 27, 2002
    397
    Fremont, CA
    Having recieved the wrong prings the first time I lifted my truck... yeh they will fit if your determined.. they will actually work with the stock hanger locations but you MUST have longer front shackles... the longer spring with stock shackls will be directly against the frame and they will do damage to said frame...
    I chose to get the correct length springs.
  7. TONYP
    Aug 13, 2002
    2,116
    so cal
    thank for the info.....don't need to be adding anymore work to the truck then I have going on right now.. /forums/images/graemlins/k5.gif
    /forums/images/graemlins/angryfire.gif <font color="red">ANGELS IN 6 </font color> /forums/images/graemlins/angryfire.gif
  8. cornfed
    cornfed 1/2 ton status
    Oct 15, 2001
    295
    washougal wa
    Hey you can just remove the four rivets holding the front spring hanger and move it forward so the rear holes in the hanger line up with the front holes is the frame and use bolts in those two. Drill one more in the frame for the inner front hole. You have to grind the hanger a little bit to fit the frame tightly. My suburbans left the ground a few times in the sand with this setup and no problems so far!
  9. TONYP
    Aug 13, 2002
    2,116
    so cal
    so what is the lenght of a front 72 leaf spring?
  10. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    Just checked a set of stock springs and the ranchos on my rig. And both are at 43.5"s center of eye to eye. /forums/images/graemlins/grin.gif
  11. TONYP
    Aug 13, 2002
    2,116
    so cal
    thanks for the info.... /forums/images/graemlins/thumb.gif
