Front left hub getting hot and brakes pulling to the right
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by kiley, Jul 1, 2003.
  1. kiley
    kiley Registered Member
    Mar 5, 2001
    87
    Salem, Oregon
    I don't seem to have and brakes on the front left side, it's pulling hard right when brakes are applied. I checked the front left hub when I got to work and it was fairly hot. What could be the deal? Bad bearings and bad break pads?
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    How old are the brake hoses? It sounds like the left one is swollen shut on the inside.
  3. kiley
    Mar 5, 2001
    87
    Salem, Oregon
    They are newer braided lines, just don't know how old.
  4. mastercraftkpk
    mastercraftkpk 1/2 ton status
    Mar 12, 2003
    192
    Houston, TX
    Is the right hub hotter than the left, or are they the same? It may be something as simple as a stuck caliper. Either the left caliper stuck open (clogged line, bad caliper) or the right caliper not releasing all of the way causing it to grab earlier than the left.
    Lift the front and spin your wheels by hand. You should be able to hear if the right side is dragging. If not, check the calipers and pads.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
