front lift spring width
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Big'nBadK5, Jul 10, 2003.
  1. Big'nBadK5
    Big'nBadK5 Registered Member
    Feb 9, 2003
    84
    Pjs, Ny
    i am smack in the middle of putting in a 4 inch set for front springs and it just occured to me that the stock springs are about a half inch wider then the lift springs? is this a common thing? and how do i fix it. i was thinking about stacking some washers on wither side to make up the difference. thanks in advance.
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    While stock springs may flare out to around 3" wide, its nothing to be concerned about since all aftermarket lift springs for GM's are 2.5" wide. The fronts will match the rear springs at the same width, too. Just fasten everything together and don't worry about it. 99.9% of the guys here did the same thing. /forums/images/graemlins/thumb.gif
  3. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    I ran into the same problem with my Skyjacker springs. There was a lot of slop in the front spring hanger. I have seen other rigs with thicker bushing on the front hanger. The thicker bushings make up for that extra 1/2 inch. Does anyone know who makes these? Part number?
