Front lift springs and add-a-leaf question...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 83k5inthefort, Jul 11, 2004.
  1. 83k5inthefort
    83k5inthefort Registered Member
    Jul 5, 2004
    20
    Seattle
    Hey everyone,
    I know you suspension junkies can help with this one...
    I've got an 83 K5 which had been sitting next to a curb for a year when I bought it. The 2" lift springs had started sagging to the right as a result. I replaced the rears with 4" lifts, now I'm looking at the front. The passenger side front springs sag about 1/2" as compared to the driver's side. If I were to add-a-leaf to each front spring, would the one sided sag go away, or remain, just 2" higher? Is it a better idea to just replace them both with 4" springs? I would like to avoid the cost/trouble if possible. Any other low cost options? Can the springs be re-curved at this point?
    Thanks in advance! /forums/images/graemlins/1zhelp.gif
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Not cheapest , but easiest way to be evn on both sides ( provided its IS ONLY the problem with springs ) is to buy new , or send/take to spring shop for rearching /forums/images/graemlins/k5.gif
    I think add-a-leaves would probably ride stiffer up front, on top of the already stiffer lift springs, as well as still listing to one side /forums/images/graemlins/thinking.gif
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I honestly belive, you'd be better off installing a set of new lift springs. BDS and Tuff Country make some good ones.
  4. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    The add-a-leafs are usually used on stock (very flat) springs. If the springs are already 2" arched then the add a leafs are not gonna do much for height but will certainly kill the ride. Most older trucks lean about a 1/2" to one side or the other any way. Best bet is new springs.
  5. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I agree you're better off with new springs. As for the trouble of changing the springs,.. it's less trouble to change them (IMO), than to add the leaf. Cost, well, yes it's going to cost more for the new springs, but at least you'll know you did it right.
  6. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    A back yard mechanic's way of fixing that problem would be to raise the passanger side tire off the ground (using the frame as a lifting point) and allow the spring to hang supporting the weight of the axle. Then take a torch /forums/images/graemlins/weld.gif and heat the spring allowing it to be pulled or re-arched a bit. I've seen it done quite a few times on kinked springs with fairly good results. But heck... I've seen a leaf spring get welded before!!! /forums/images/graemlins/yikes.gif
  7. backcountry
    backcountry 1/2 ton status
    May 27, 2004
    916
    For the front I would get new springs. You don't want to chance it especially on the front by rigging something up to just get by. /forums/images/graemlins/peace.gif
