front lift springs!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazing86, Jun 22, 2001.
  1. blazing86
    blazing86 1/2 ton status
    Dec 24, 2000
    290
    any ideas or tricks to installing these? I cant get the jackstands far enough forward to support the weight of the engine.
  2. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    I used the taller jack stands from Sears. Supported it right next to the front mounts on the cab.
  3. NOT4SHW
    NOT4SHW Guest
    I used the 6 ton jack stands from wal mart and had to place them on top of (2) 6"x6" blocks per side (blocks were set side by side) and placed them just behind where the frame starts to go up into the engine compartment.
    '79 K5,13 1/2" lift, 39.5 TSL's,15x12 Eagles,350,t-350,warn 8274,
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I always put 2 4x4s next to each other on the ground and put my jackstands on top of that.
    When I swapped my front axle yesterday I jacked up one side, took the tire off, then lowered the truck until the axle was only a few inches off the ground. It made it much easer to get the axle in place that way.
    Tim
