front lift
Discussion in 'The Garage' started by 1979jimmy350, Dec 10, 2004.
  1. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    is it possible to make the front reat shackles longer to get about 4 inches of lift? if so what type of steel should be use?
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    No, you will kill your caster angle and it won't work. You need to use lift springs for the front. A small amount of lift can be had out of extending the front shackle but not 4".
    Harley
  3. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    can the spring perches be change to compansate for the change in caster?
  4. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I am not 100% sure what you are asking but I assume you are asking if you can make the back hanger on the front springs longer to get 4" or lift.
    The answer is not really. You would need to lengthen the hanger by 8" to get 4" of lift at the axle. By doing that you would throw driveshaft angle and caster/camber WAY out of wack.
  5. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Harley beat me too it!
    That is fairly difficult because one of the perches is cast into the diff housing.
