Front locker or posi on snow/ice for D60
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 80blackgmc, Feb 28, 2007.
  1. 80blackgmc
    80blackgmc Registered Member
    Nov 21, 2004
    43
    Hey guys.
    I am in the process of getting all the parts for a D60 buildup. Will be 4.56 geared diff.
    My '80 is a part time daily driver for the most part. I would like to be able to go offroad a lot, no rocks around here, just good old crazy mud, and deep snow. However in the winter roads get icy, and, it does see a fair amount of street driving.
    From everything I read, most ppl. don't like having the front end traction aided on any kind of ice/snow. So here is my question.
    If I get a posi, or a locker for the front (Detroit or a True Track), and run on the street with just one hub locked, will this work ok, be hard on the diff, or be a total waste of time?
    I think the best opton for me would be the Ox cable locker, but its a STEEP price to pay for a truck like mine.
    For the 14 bolt I think I would either go with a detroit locker, or the Eaton posi. My 05 dodge has a limited slip out back and open diff up front and it does OK on the ice/snow with the same tires chevy will be running on. In fact I feel there is more traction with the dodge then chevy, but the dodge is a bit more tail happy on ice.
    I live in Calgary, Canada.
    Let me know what you guys think before i start buying my parts. I want this truck to be a good combo of daily driver ability and a decent offroad rig. I think the 4.56 gears it has now are a bit steep for highway, but with 37" tires should be reasonable, while still maintaing the gear ratio that would work well with even 38.5" tall super swampers.
    I could step down to 4.10s during this build, but, am thinking it might be taking a step backwards if I ever put big tires on, or, want to resell the diffs.
    Thanks,
    Igor.
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    Don't lock just one hub with a detroit in the front. The truck will pull very hard to one side when your foot is on or off the gas. It will be much more predictable if you leave both hubs locked.
  3. 80blackgmc
    Nov 21, 2004
    43
    Thanks for the reply.
    So i guess I'm most likely either stuck with leaving it open, or, going to a selectable locker.
    Anyone else out there that has traction aid on a similar truck/similar roads?
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I can't talk from experience, only what I've seen. I reckon a selectable is the only way to go for snow and such. Turning is a bitch with a locker and under power.
  5. 1977k5
    May 26, 2003
    9,992
    130
    I don't usually need 4wd in the snow anyway, but I have had the front locked in a few times. IMO if its slippery enough out that you really need 4WD, having a detroit up front isn't so bad.
  6. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    just leave the front open, less wear on parts and better for the snow. imo
  7. 80blackgmc
    Nov 21, 2004
    43
    I don't think leaving it open in the mountians during heavy snow is really an option. There are tons of hills that you simply need 4wd to climb, unless you have a zillon lbs in the bed.
    Selectable is great, just so friggin expensive. But at the same time, by the time one buys a locker, and a cover, its not THAT much more to step it upto a selectable locker I guess.
    That cable one just looks great. Any electric ones out there?
    Thanks.
  8. 1977k5
    May 26, 2003
    9,992
    130
    There are 3 electric ones: Detroit Electrac, Eaton E-locker and Auburn Ected. The Detroit Electrac is not produced anymore, likely due to issues with the locker. The Auburn Ected is not a true locker. I like the Eaton E-locker.
    ARB's are the most popular selectable locker.
  9. 80blackgmc
    Nov 21, 2004
    43
    The more I read the more I think the best would be the Ox Cable locker up front (if I can afford it, open if not) and open in the rear.
    For now don't have to touch the rear axle. So might as well keep it open, and one day either put an eaton in, or a detroit.
    I would even be willing to try a gov lock, but my trans/diff builder says its gonna be a waste of time/brake.
  10. onetonbb74
    Dec 1, 2005
    2,083
    Campbell, CA
    If its that nasty, then get detroits, there pretty pricy for the front, but the rear is cheap for a 14ff. Id personally leave the front open and rear would be locked.
  11. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    I run a lock-right in my front axle in the summer and just remove it and replace the spider and side gears for the winter. It's a lot cheaper than a selectable locker.
  12. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    The "only lock one hub" just doesn't seem to work very good. With a locker it pulls to one side all of the time, and with almost any limited slip you might as well just leave it in 2wd because you won't get any power transfer to the side that's locked in anyway.
    I have not been impressed with the Ox cable lockers. Several guys in our club have them and they are always having trouble getting them to engage and have to constantly adjust the cable.
  13. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    Labor intensive though...:confused:
  14. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    Posi's are for grandma's IMHO :D .
    Lock it.
    My front diff. is spooled ($150.00) with lock outs.
  15. loafer
    Aug 19, 2003
    634
    Lyman, Maine
    Not realy. Every fall I have to service and/or replace the wheel bearings and spindle bearings after a summer of mud and water anyway. With spindles off it's not much extra work to pull the axle shafts and diff cover. This is also a good opertunity to inspect/replace u-joints and change the gear oil.
  16. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    Okay,
    Why hasn't anyone suggested a Power-Lok? It is the most aggressive limited slip out there and will work fine in the snow and give extra bite in the MUD. I put one in my 83 K10's Dana 60 for the same concern of getting into snow/ice. Locked up front in heavy rain, let alone snow and ice can be hazardous. I'd go with a Power-Lok. Good price, easy install, great traction and good all around for the D60 on parts.
    JMHO or .03 at the current rate of inflation.
    Manny
  17. onetonbb74
    Dec 1, 2005
    2,083
    Campbell, CA
    Powerlok traction carriers are expensive brand new. Unless you get it used, they are pricy especially 35 spline units for a d60. A big upside to them is the rebuild kits that make them rebuildable when the clutches go then again thats another 100 dollars but hey, you cant get a rebuld kit for most posi's. My friend has one in his ramcharger with the big sx's and he rebuilds it every couple years. Ive driven in snow with front and rear lockrite lockers, and it turns ok but your going slow anyways really didn't have any problems definately didnt feel like a brand new truck or anything of that matter.
  18. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    Hey Oneton,
    You're exactly right but they are worth their weight.
    Manny
