Front locker?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by snowtoy, May 10, 2002.
  1. snowtoy
    snowtoy Registered Member
    Mar 18, 2001
    30
    Norway
    I want a locker in front on my trail rig. It have a welded rear and is only driven on trail. Who is a truck with auto locker to drive in sharp turns. Do alot of copetition so a have to go 4wd all the time and some times very sharp turns.
    check out:
    http://www.arendaloffroadklubb.com/bilder0605.htm
    and
    http://www.eurotrial.no/
    My offroad club and pics of last copetition.
  2. deothrwhtmt
    deothrwhtmt Registered Member
    Feb 24, 2001
    61
    Maryland
    ARB is selectable. You an stay on if you want and turn it off when you dont need a full locker.......good for turns.
  3. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    I would say go for it. put in an ARB air locker. Good luck
    NITRO
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    there is always a discussion between ARB and Detroit guys in regards to front axle use.
    I lean to the detroit guys side
    <a target="_blank" href=http://www.sierrarockcrawlers.com/yabbse/>http://www.sierrarockcrawlers.com/yabbse/</a> several of the gents on this board run front detroit
  5. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    ok, then go for a detroit /forums/images/icons/smile.gif
    NITRO
  6. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Just weld the front as well. Then use proportion valves inline to your brakes. This will lock each/seperate wheel or at least slow down the pivoting wheel. You can get away with everything you want. I stand behind the detroit, when its in the REAR.
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    if the axle is spooled proportional brakes dont work at all.
    something about a solid link existing between the 2 tires....
    RedDwarf runs lockrites front n rear, essentially the same, with good results.
  8. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    I run a Detroit front and rear. I think the 'Detroit's don't turn' is either a stretch or a theory - I'm here to tell you I have had NO problem turning on a trail - in sand UNDER power (and I mean power) it didn't want to turn tight, but pulling off the gas got it going where I wanted. When we ran TSF in March, with mud/snow/muck it went exactly where I wanted it to go. I absolutely love my Detroit - reliability and positive traction when you want it, no questions asked.
  9. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    If you twin stick your TC, then put it in Front wheel drive only and pull the steering brake on the rear side you want to go.
  10. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    if the rear is spooled it doesnt matter which side you brake on,
  11. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I am definitely going to find a detroit for my front axle to try
