Front mount receiver
Discussion in 'The Garage' started by rpellicer, Feb 1, 2005.
  1. rpellicer
    rpellicer Registered Member
    Dec 20, 2004
    38
    Susanville, CA
    Does anyone know who makes a front mount receiver for a '91 Blazer? I've been looking online, but I've only found them for '92-up.
  2. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I don't think anyone does. '92 and up would be IFS rigs like my DD.
  3. goldwing2000
    goldwing2000 Guest
    Well... I do. :D
    I made one for mine, anyway. If you know how to weld and have some 1/2" steel plate, it's not that difficult.
  4. renny
    renny Registered Member
    Apr 20, 2004
    30
    Salem, Oregon
    Hidden hitch used to but now Warn is the only company I know of that makes one. The problem is its expensive I was quoted $225 bucks for it when the warn classic winch bumper would be $335 and $104 dollars for the bumper and the mounting kit.
  5. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    Warn makes them, as noted, for the 81-87/91 body style. Leastaways they did two years ago or so when I put one on the Burb.
    Nobody makes 'em for 73-80 that I've found -- 'cept, as noted, custom jobs.
    -- A
  6. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Leadfoot067 has one on the front of his K30... he maybe able to help you out a little?:dunno::dunno: :dunno:
  7. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    I fabbed one in my bumper. You can buy the receiver part at a trailer supply shop. Then use some flat plate at least 3/8" thick with some bracing.
    It is a fairly easy project...
  8. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    Cabela's lists a Warn for your application. It's $180. A little pricey, but if you don't have access to a welder it's your best bet.
  9. goldwing2000
    goldwing2000 Guest
    I never would have thought to check Cabela's. :confused:
  10. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
  11. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    That was a great idea!
  12. rpellicer
    Dec 20, 2004
    38
    Susanville, CA
    Found the ones by Warn, thanks. The custom built ones seem interesting though. Maybe time to take a trip to wrecking yards to find one wide enough that I can chop to size.
  13. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    I made this one about ten years ago. It's been on 2 K-10's and now my '73 K-5.
    Even pulled up a few small trees and listened to the frame groan and squeek winching with my Warn i9000.
