front output seal on 208 tcase????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TIGHTWORK82 K5, Aug 1, 2002.
  1. TIGHTWORK82 K5
    TIGHTWORK82 K5 1/2 ton status
    Oct 21, 2001
    140
    orlando , florida
    my front seal is leaking on the tcase.
    i have never changed one out ?
    how difficult is it, how much for a new seal?
  2. GRINCH
    GRINCH 1/2 ton status
    Jan 30, 2001
    1,951
    Helena, MT
    Easy and only $8.00. Drop your front drive shaft, remove the yoke, pull out old seal, reverse process and your'e done. Should only take a 1/2 hour max. Depending on beer breaks!!! The one thing you need to make sure is that the yoke is not grooved. Mine was, you will have to buy a speedi-sleeve. I got mine from NAPA for $16.00. Be careful putting the sleeve on the yoke it's thin. I used liguid steel under it to fill up the grooves. If you don't the sleeve is soft and thin enough to collapse into the grooves and it will leak again.
    Good luck...
  3. TIGHTWORK82 K5
    Oct 21, 2001
    140
    orlando , florida
    thanks boss!
