front pinion angle options???
Discussion in 'The Garage' started by reeser, Dec 6, 2003.
  1. reeser
    reeser 1/2 ton status
    Oct 8, 2001
    434
    Hayden Lake, ID
    i need to shim my front end to give my new 1350 joint on my dana 60 a better operating angle. however i have a problem my tuck only has 2.7 degrees of positive caster so shimming the front end will kill my caster. i heard that i can put new bearings in my front end to adjust my caster is this true? what are my other options??? thanks.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Your transmission is twice as long as mine and you've got front shaft angle issues?
  3. earl87gta
    earl87gta 1/2 ton status
    Apr 6, 2003
    551
    Chuckey TN
    you could have the knuckles turned but that may be a little $$$ or you could instal a dubbler so you can use a longer drive shaft. /forums/images/graemlins/thumb.gif
    Earl
  4. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    just go 1410 in front, it can handle a greater amount of angle than the 1350. /forums/images/graemlins/grin.gif
    j
  5. reeser
    Oct 8, 2001
    434
    Hayden Lake, ID
    ya go figure and i only have 6" of lift plus a 1" drop on the t case. talk about pissin me off!!! /forums/images/graemlins/mad.gif
  6. reeser
    Oct 8, 2001
    434
    Hayden Lake, ID
    Earl
    i'm seriously thinking about it, great excuse i guess. /forums/images/graemlins/grin.gif
  7. reeser
    Oct 8, 2001
    434
    Hayden Lake, ID
    j
    i've heard that but i didn't know if there was any truth to it. i have a 1410 yoke off a 70 it should make the swap. i think thats what i might do.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Raise your transfer case back up! That's why your front shaft angle sucks so bad.
    Where is it binding?
  9. reeser
    Oct 8, 2001
    434
    Hayden Lake, ID
    say whaaaaaa????????????? it's binding at the yoke on the dana 60. lowering the t case improves the angle and helps fight binding. /forums/images/graemlins/thumb.gif
