Front pinion anlgle sucks
Discussion in 'The Garage' started by JEBSR, Jun 6, 2006.
  1. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    I know this has been discussed a million times but I have searched for two hours and not found the answer sooooo here goes.
    After the last lift I put on my front pinion is angled down around 8 degrees. In four wheel drive it's ok until I get on it real hard. I can hear the front ujoint bind up. It drives ok, steering self centers, etc.
    My question is how do I find the happy medium to shim the axle up correcting the angle without disturbing the steering to much?
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    trial and error for the happy medium. shim it so that the u-joint won't bind and see what happens then adjust from there to what you can live with steering wise. Or go all out and get the pinion angle correct and have the knuckles cut and welded.
  3. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Down 8*? Got a pic?
  4. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    That shouldn't self-center then, should it?
  5. resurrected_jimmy
    May 23, 2005
    2,241
    my guess is NO !!!!!!!:eek1:
    Thinking about it, sounds like the shims need to be flipped around
  6. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    Or the springs are installed backwards.
  7. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    well one thing you can do (people do around here) is 1 of 2 things...
    1 divorced t-case
    2 have axle rotated...
    they even rotated the axle on xtreme4x4 the show...
    they grind the welds off the spindles and rotate the pumpkin.. this leaves all steering geometry alone..... I almost had to do that... I was up 12" and even with a 2" drop tcase I still had a bad front d-shaft angle.... I was gonna do rockwells but NJ said no... so down she came and didnt have to worry about it...
    Look at that shaft angle!!!
    http://68.36.135.34/PROJECT_NJLEGAL/Pics/truck/truck5.jpg
    stock push pull steering sucked majorly too
    http://68.36.135.34/PROJECT_NJLEGAL/Pics/truck/1024_steering.jpg
  8. divorced
    Jul 20, 2004
    5,115
    I wouldn't think so. I put longer shackles on mine and it wouldn't self-center, and it was no where close to being pointed down. I wouldn't think it would even be drivable if it was 8* down.
  9. resurrected_jimmy
    May 23, 2005
    2,241
    Do ya'll think we may be interpreting this wrong....... maybe he means it is 8* below where it needs to be? 8* below horizontal doesn't really seem like it would even function:confused:
  10. divorced
    Jul 20, 2004
    5,115
    Ya, I'm thinking for sure we are reading it wrong. A pic would help more than words probably.
  11. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    if the front cv binds is that really bad? or is it alright if its just for 4wd use for a while until a high angle shaft is made?
  12. resurrected_jimmy
    May 23, 2005
    2,241
    Its bad, you need to fix it asap
  13. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    The binding will find a weak spot. And puts lots of stress on tcase, mounts, everything.
  14. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    That's what I meant, sorry. I just got home and it's raining but I'll try to get it in the garage and remeasure it to be sure. I'll get a pic if I can.
    It has 4" spring with a 7" shackle.
  15. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    :eek1: :eek1: :eek1: Just take 2 seconds to think about it, what could be good about the CV binding? Oh and why would it be okay to use in 4wd? Thats the only time its going to bind :wink1:
  16. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    Ok got some pics but didn't have time to recheck angle.
  17. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Did you take a grinder to the yokes?
  18. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    no not yet, gonna do that and the shims at the same time. soon...
    Taking it out every thurs for next three weeks for training so got to keep it together until I get shims figured out and ordered.
  19. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    well i was saying that its the front, if it was the rear it would be binding all the time and it would not last long at all. but i thought that since its only when 4wd is used it would last a lil since i wouldnt use 4wd alot.
    i took 2 seconds to think about it, and i was just wondering if a little binding would be ok or if its the kind of thing that will rip it off or something. ive got a new 1350cv shaft but its too long so i cant put it in til i do my 52 swap. im jus seeing if this shaft would get me by for a couple weeks
  20. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I think the problem is your shackle. It is so long it is rocking the axle down just put some shims under the springs and bring it back up to where it needs to be or move the rear mount up to the top hole on your shackle. I have 4" springs and I run the 4.250" shackle from ORD. and my pinion is almost perfect and my caster? is at 8*
    Ira
