front pinion
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ed1507, Apr 13, 2003.
  1. ed1507
    ed1507 Registered Member
    Jan 25, 2003
    70
    indiana
    any on know if there is a race on the pinion too i have one in the housing ed. /forums/images/graemlins/confused.gif
  2. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    The bearing presses on the pinion with the spacer shim between the bearing and the head of the pinion, The race for that bearing is in the inner portion of the housing, the outer pinion bearing race (next to the yoke)is pressed into the housing where the pinion shaft comes out. Both races are in the housing, both bearings go on the pinion.
