front/rear bumper bolts...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Bone85K5, May 14, 2001.
  1. Bone85K5
    Bone85K5 1/2 ton status
    May 7, 2000
    436
    Columbus, Georgia
    How do i get these out? I got out a few...the rest just turn but the nuts dont come off, the bolt and the nut turn together..I have been soaking them for a few days with PB stuff and WD40..any ideas?
    Ben
    www.BenjaminBone.coloradoK5.com
  2. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    If I remember right, there's a square collar on those bolts that sit in the bumper so you can unbolt it without needing something to hold onto the bolt head. If these are stripped or missing, try getting on it with some vise grips and use an impact gun in the nut (after you make sure you have a good grip) All else fails, drill through the center of the head (use a quality bit, these bolts are strong) until you can knock the bolt head off and replace it with a new one. .....Have you considered using heat??
    Why do people keep calling it a Bronco!!!!! [​IMG]
  3. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    They have a square head that sits in the bumper flat to prevent it from spinning around. They sometimes can be a pain in the ass to get off.
    <A target="_blank" HREF=http://community.webshots.com/user/vwryda>http://community.webshots.com/user/vwryda</A>
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    It's called a "carriage bolt" and, yes, it does have a square shank under the round head that is supposed to lock in the square holes on a bumper. They frequently round out. If it does, your only choices (unless you get lucky and the vise grips hold, not likely) are to drill/burn off the bolt head, burn off/split the nut, or tack the head (with a welder) and cut it loose after removing the nut. The third option would not be good for a chrome bumper. [​IMG] One other option is to take a nut and weld it to the rounded bolt head (through the hole in the nut) so that you can hold onto it. This also works with other "rounded off" bolt heads.
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56 Locked
    Soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  5. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    BadDog is right. I had to drill out my carriage bolts out when I switched out front bumpers. It sucked and took a while, so be prepared.
    '73 K5
    Chevy good...Ford bad
