front seals
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by shooter, Aug 13, 2001.
  1. shooter
    shooter Registered Member
    May 24, 2001
    18
    Colorado,USA
    I have a 72 Jimmy, I am installing a new set of "U" joints on the axles that go to the hubs. I need a set of seals that go the the axles, then the axles go inside the spindle. NAPA gave me a set of seals that just look like wheel seals. Are these correct or did I recieve the wrong part???
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The kit that I got came with a neddle bearing, 2 rubber seals (w/o a steel shell just all rubber), a plastic thrust type washer, and a metal ring to make the kit work on 69-72 axles (with a 5-260x u-joint). If you have the 73- axle shafts then just don't use the steel ring.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
  3. shooter
    May 24, 2001
    18
    Colorado,USA
    Thanks for the response, How do I tell if I have 73,axle shafts? Also, Since I bought the Jimmy, I have had to change the front axle joints about 5 or six times and I don't do alot of 4wheeling. could it be that these are the wrong shafts for a 72? I bought the Jimmy in the mid 1980's, and it seems that whenever I check the front bearings the joints are rusted and worn out and they are supposed to be the seal type. Any help would be great.
  4. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I should have taken pictures of them when I had them both laying around. The newer axles had a larger flange on them for the seal. When you buy the kit (mine was a CR) you will see the difference. Try packing them with marine grease (it is waterproof) to make them last longer.
  5. midnitlove
    midnitlove Registered Member
    Mar 19, 2001
    53
    Orange County, California
    I just put new axles in April, and I had a hell of a time trying to find those seals. I never found them. No Napa or Chevy dealer had them or junk yard or anywhere. I just greased everything up and the axles I bought seem to have a good enough covers/seals on them to work properly. It seems to work fine so far. I was told the same thing about changing your axles to 73 and up because parts are easier to find. Seems like a job to me.
    <font color=red> AMIGOS SO. CAL </font color=red>
  6. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    This might help the guy behind the counter find it. The part # on the box that I got is CR BK1 it came in a SKF box (CR's bearing brand). I think NAPA carries them but I got mine ftom pep girls
