front seats for k5
Discussion in 'The Garage' started by aknight_sa, Nov 24, 2005.
  1. aknight_sa
    aknight_sa 1/2 ton status
    Oct 14, 2005
    305
    Saudi Arabia
    hi all,
    i need to change the seets on my 1981 Jimmy, would new seats made by GM fit? or do i have to find something specific for this model.
    thanks
  2. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    If you're looking for something that bolts right in, then stay with trucks that have the same body style as yours. Most seats will fit with some fabrication of seat mounts, or buying seat mounts from aftermarket sources. The best advice is to find a seat that you like, then adapt it to your truck (build or buy a mount).
  3. ZooMad75
    ZooMad75 1/2 ton status Premium Member GMOTM Winner
    Apr 5, 2003
    1,004
    605
    Pueblo, CO
    I bolted in a pair of Buckets from a 2002 Silverado. Didn't require much fab work. Just had to make some brackets out of flat stock. The brackets bolted to the floor in the stock location and then to the stock 02 seat tracks. Took about an hour or so per side and that was with just hand tools and a cordless drill.
    The silverado buckets did eleminate the flip forward ez-entry feature of the stockers, but the back folds forwards and it slides far enough to allow just as much access. I did get the added feature of the integral 3-point belts too. (my 75 only came with lap belts)
    Here is a shot of mine after the install: (sorry for the darkness)
  4. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    if you're cool with sticking with stock type seats, check the junk yards. i picked up to bucket seats in perfect condition for 20 bux each yesterday. just a thought.
    colby
  5. absolute
    absolute Registered Member
    Apr 7, 2005
    77
    Near Spokane, WA
    Don't exclude S-10's! I put a great set in the K10 for $40 , they were in great condtion and the mounts were easy to build!
  6. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    Did you use the stock K5 brackets that mount to the floor and build a bracket off those for the Silverado seats or did you use the floor mount brackets from the Silvy seats and modify them to mount to the stock floor location? By the way, looks good! Thanks!
    Kris
  7. ZooMad75
    Apr 5, 2003
    1,004
    605
    Pueblo, CO
    You can't use the stock K5 bracketry. It would make the seats sit 5" over the console. The seat frame/tracks for the silverado seats are tall to start with. My original plan was to unbolt the silverado tracks and mount them to the stock K5 parts. One problem. Looking at the silverado seats, the tracks don't bolt to the frames, they were not coming off. I think it's because the integrated seat belts as the seat frames/tracks have to take the force of an impact with the seat belts. Not a big deal though, I unbolted the stock seats and set the silverado seat in place and the hieght was right on the money.
    Really all I had to do was take some 1/4" flat stock (2"wide) and after taking some basic measurements, cut and drilled it to fit the stock seat mount holes in the floor and then the silverado tracks. I used grade 8 hardware to bolt it all together. I've had them in for over a year and been over a variety of trails and with my fat butt in them I've not had one problem.
    The stock silverado tracks have a LOT of front to back travel. I can't use all the travel to the back because of the 75's lack of a rear footwell. Still it goes far enough back for me. 77 and later with Silverado seats would have another 2-3" of rear travel.
  8. BlahBlah
    BlahBlah Registered Member
    Apr 13, 2005
    10
    Oregon
    Absolute can i see a pic of the mounts you made. I'm trying to stick some 300z seats in my K20, and I'm tryin to get some ideas on how to build the brackets for em.
  9. Janitorjim8
    Janitorjim8 1/2 ton status
    Feb 21, 2005
    215
    Illinois
    i just installed racing seat from ebay in my truck. Not to bad to install, just put flat 1/4 steel over the old brackets, drilled into that, then bolted the seats to that. I still have the old seats but it says your in saudi arabia.... not sure how i'd get them to you
  10. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Do you have a review for us on the ebay seats. Maybe a link to the auciton. Are they factory? I am looking into some JDM seats but not sure. I need something to use a harness with.
  11. aknight_sa
    Oct 14, 2005
    305
    Saudi Arabia
    do you have a pic of your old seats??
  12. Janitorjim8
    Feb 21, 2005
    215
    Illinois
    http://cgi.ebay.com/ebaymotors/Red-...ewItemQQcategoryZ33701QQitemZ8019641477QQrdZ1
    thats the link for the seats, ingnore that they say for honda civic... I love the seats, look great, feel great. If you are very used to a regular seat the racing seat takes a bit of getting used to, when you are in it feels really nice actually. Not made for larger people, i am 180, 5'10'' so probably no more then like a 220 person. I do not have pics of either but can try to get them tommmorow
  13. aknight_sa
    Oct 14, 2005
    305
    Saudi Arabia
    height wont be a problem... i'm only 5'7"
    it looks really nice.. what i need is something comfortable to sit on... the ones i have now are in a really bad shape
  14. RubberFloorMat
    RubberFloorMat 1/2 ton status Premium Member
    Dec 12, 2004
    395
    43
    Oklahoma
    so is that 249 for 2??
    if thats the case, screw the Tahoe take outs..
  15. Janitorjim8
    Feb 21, 2005
    215
    Illinois
    yea thats 249 for both of them, you may even be able to find them for a little less if you look around on the page. Not all that hard to make them work either/plenty of color choices
  16. BillyTungsten
    BillyTungsten Registered Member
    Jul 24, 2005
    63
    Minnesota
    They look nice, esp. at that price... but the ad does not mention the seating material. Cloth, vinyl, anyone know?
  17. BillyTungsten
    Jul 24, 2005
    63
    Minnesota
    TTT... I may buy a pair for Christmas, but not if they are cloth... anyone? Beuhler? Beuhler?
