Front seats.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JimmyJuneau, Aug 22, 2003.
  1. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    I am looking to replace my front seats in my truck but not sure on how to do it. If I go to a junk yard and get say like a pair of bucket seats out of a dodge truck is there a conversion bracket I can buy for it?
    Who has doen this sort of thing before? DO you have any pictures of the swap if so post them thanks.
  2. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    I just put some 2000 cavalier seats in mine. I guess there are many ways to mount differant seats, depends on your application. Mine were skinnier and shorter mounting wise from the stockers so I welded a plate on my stock brackets then drilled holes through the plate to bolt to. You could also use the stock bracket off of the new seats if it sits at the right height and then drill new holes in the floor board, I will try and get some pics uploaded in my webshots page this weekend www.webshots.com/alf4444
  3. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    the link to your pics is no good........ /forums/images/graemlins/frown.gif
  4. patrickcampbell
    patrickcampbell Registered Member
    Sep 11, 2002
    60
    ive got a set of stockers "mint" from a 77 with brackets, that would be the best way to go! <font color="red"> </font> /forums/images/graemlins/thumb.gif
  5. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    When you get to the salvage yard, ask for a set from a 90-03 Suburban, Tahoe, Yukon or Extended cab pickup. They literally bolt in. In worst case you'll have to drill a couple of new bolt holes. I installed 96 Yukons and they were a 30 minute swap. 2 Door Tahoes, Yukons or Extended Cabs have the best seat as they'll slide forward as well as flip forward for better access to the back seat area.
  6. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    any pix? are they buckets?
  7. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    anyone think the rear seat (2nd row) from a yukon would come close to bolting in for a k10?? we're talking bench seat..no power, just about the same as my front seat..but leather..
  8. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    Does anyone have any pictures of their conversions?
  9. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> THere are a couple pics of the seats in my truck here. They are out of a '92 Integra, I just made a simple rectangular frame out of 1.5" square tube, the welded tabs to the frame to bolt it ot the original holes in the floor and bolted the seats directly to the frame. I can get more detailed shots if you want. </font>
