Front Shackle length
Discussion in 'The Garage' started by stockk5, Mar 17, 2007.
  1. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    Hey guys, just wondering about shackle lengths for the front of k5's. I know that longer shackles push your pinion down. My question is how much longer can they be, i dont want more lift, just my friend has a set of daystar front shackles. A replacement thats thicker than stock shackles. The replacements are 8.75" long, looks to be about 1.5" longer than stock i believe. How would this effect pinion angle? Good? bad? Thanks guys
  2. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    8.75" eye to eye or overall? If eye to eye, in my opinion that is far too long.
    Factory is 4". That much longer would almost certainly have negative effects on the pinion angle unless for some reason it was altered the other direction from some other modification.
  3. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Also just remember that how ever much longer the shackle is from hole to hole will net you half that distance in lift.
  4. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Longer shackles arent really any better unless you move the mount for a better shackle angle...
  5. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    x2.
  6. RGV72BLAZER
    RGV72BLAZER 1/2 ton status
    Jan 23, 2006
    2,425
    Edinburg*San Bene*Online-The Real South Texas
    i have a shackle that's 8" eye to eye & i can already tell i'm going to have to do something about the pinion angle. pinion is pointing down already with no d-shaft attached...that's with stock 52s moved forward but the shackle in the stock location. i agree that 8.75 is too much, but you could always try 'em out and redrill them to a shorter length.
  7. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    once you relocate the shackle location forward, it'll be much better
  8. 79k20350
    Nov 22, 2004
    7,757
    Ct
    x2... Becuase the shackle is at an angle the distance it rotates the pinion down is much less if anything notcieable at all...
  9. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    Shane from BlackWidowPerformance sent me a set of 5" HD Front Shackles. They are awesome. They will not have an affect on the pinion angle as best as I can tell. Yes, they are 1" longer but that equates to only 1/2" difference. I will be installing them shortly on my 83 K10. Keep an eye, no pun intended, out in my post.... Manny's 83 K10, for details.
    Thanks!
    Here's a pic:
    1/4" good old American steel, baby!
    Manny
  10. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    alright yeah i figured they were way to long. I dont want any more lift, i just wanted beefy shackles, guess ill be fabing up my own.
  11. 79k20350
    Nov 22, 2004
    7,757
    Ct
    Just redrill them.. I think they are h shackles but that shouldnt be too big of a deal...
  12. 79k20350
    Nov 22, 2004
    7,757
    Ct
    1/2" of lift but it still pushes the back of the spring down 1"... Now im not sure how much thats going to affect castor (or camber i dont remember) but its definetly going to have some affect on a stock style setup...
  13. RGV72BLAZER
    Jan 23, 2006
    2,425
    Gen1 guys have a different mounting points tho.
