front shackle perch mounted on frame
Discussion in 'Parts & Trucks Wanted' started by crazy427, Jan 1, 2004.
  1. crazy427
    crazy427 1/2 ton status
    Mar 10, 2003
    979
    Edison , NJ
    /forums/images/graemlins/1zhelp.gifThe perch that is riveted to the frame on the passenger side front of my blazer is bent. It is the piece that the front spring shackle bolts to . I called up some local yards but nobody has anything /forums/images/graemlins/angryfire.gif. Does anyone out there have a parts truck that this piece could be salvaged off of?
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    LMC Truck sells them new individually. Check out their web site by typing in their name. /forums/images/graemlins/thumb.gif
  3. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    will one off a 72 work? if so i have one if its in good shape ill check tonight.
  4. crazy427
    Mar 10, 2003
    979
    Edison , NJ
    I dont know if it is the same or not. Ive never seen one go bad before. I think many moons ago my truck was in an accident with the previous owner and it was overlooked and not repaired /forums/images/graemlins/angryfire.gif. It is bent over about 1 inch to the side ,not a major problem just have a small amount on shackle misalignment.but it is annoying me like crazy /forums/images/graemlins/crazy.gifeverytime i see it.Does anyone know if it is the same?
  5. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i have it and its straight. it does have a few blowtorch marks but nothing bad. i got impatient. the nut came off but the bolt wouldnt. let me know what you find out and if you need it.
    69k5
  6. txtough
    txtough Registered Member
    Aug 31, 2003
    39
    Lubbock Texas USA
    I'm parting out a 77 4WD PM me with your specifics.
  7. crazy427
    Mar 10, 2003
    979
    Edison , NJ
    I dont even know were to start looking to see if they are the same /forums/images/graemlins/frown.gifand i couldnt find them in the lmc catalog. can anyone help? /forums/images/graemlins/confused.gif
  8. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    get your measurements and ill measure mine in the morning.
  9. crazy427
    Mar 10, 2003
    979
    Edison , NJ
    ok , /forums/images/graemlins/grin.gifill let yo know tommorow
  10. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    from the front looking back
    5" outside to outside
    3 1/2" inside clearence
    1/2 holes in both side
    top is shaped kinda like a V (2 1/2 - about 4 1/2") (wider closer to the frame)
    rivited t6o the radiator core support.
  11. crazy427
    Mar 10, 2003
    979
    Edison , NJ
    OH... that is the front one..riveted to the radiator support. im looking for the frame mounted one that the front spring rear shackle bolts to on the passenger side under the doors.
  12. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I'll look tomorrow i have 78 that still has springs on it /forums/images/graemlins/thumb.gif
  13. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    Too bad I'm way over in the middle of nowhere. I'd give you one or two off some frames I have.
  14. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    ok ill check that tonight. let me make sure i got this. rear spring front hangar.
  15. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    Sounds like he's looking for the rear hanger for the front spring on the passenger side, right by the starter. /forums/images/graemlins/thumb.gif
  16. crazy427
    Mar 10, 2003
    979
    Edison , NJ
    exactly, front spring ----rear hanger... /forums/images/graemlins/thumb.gif
  17. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    ok will do.
  18. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    from the inside of the frame where its mounts
    base = 5 1/4 (front to back of baseplate)
    heigth = 1 3/4 (bottom of frame rail up)
    width = 2 3/4 (tube thing the bushing goes in) (i guess the bushing is like 3" long)
    bushing = 1 1/2 round (or so)
    these arent the most accurate measurements. kind of a pain in the but to measure. and no torch marks. this was before i got pissed that day.
    nathan /forums/images/graemlins/thumb.gif
  19. crazy427
    Mar 10, 2003
    979
    Edison , NJ
    lol.... ok ill check it out and let you know tommorow. thanks for the help /forums/images/graemlins/usaflag.gif
