Front Shackle Quetion -- how much lift?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Stoopalini, Jan 3, 2001.
  1. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    Which aftermarket front shackle will lift the front the most?
    Off Road Designs HD Front Shackle
    or
    Hill 4-Wheel Drive 1" Lift Extended Front Shackle?
    Thomas.
    -- '84 K5 Blazer --
    <A target="_blank" HREF=http://Stoopalini.coloradok5.com>http://Stoopalini.coloradok5.com</A>
  2. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    The Hill's shackle will lift the front more, but also requires a shim between the springs and axle to compensate for it's extra length.
  3. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    Do you know if the Hil Shackles come with the required shim?
    and ......... If not, where can I get it?
    Thanks for the info,
    Thomas.
    -- '84 K5 Blazer --
  4. CK5
    May 19, 1999
    21,623
    701
    CO
    ORD shackle will lift 1/4"
    Hill will lift 1-1/2" (that's what I got anyway)
    It dosen't come with a shim but they can sell you a set, I got mine at a local 4x4 shop for about 10. bucks.
    Steve
    1990 K5 with stuff
  5. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    Thanks Steve! Thats exactly what I needed to know.
    So, if my K5 sits level now with a stock suspension, and I install the ORD 2 1/2" Shackle Flip in the rear, what is the best way to lift the front an equal amount?
    A) 2" Lift Springs with ORD's HD Front Shackles
    B) 2" Lift Springs with HILL's Extended Front Shackles
    I guess the ORD's would be fine, right? Maybe the back would even sit a little higher than the front this way?
    ........ But it seems HILL's would allow for more clearance and articulation.
    Thanks again,
    Thomas.
    -- '84 K5 Blazer --
