Front shackle relocation question.
Discussion in 'The Garage' started by TruckNutzDude, Jul 11, 2004.
  1. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    First of all, I searched using everything I could think of from "shackle angle" to "relocated front shackle" and came up with NO MATCHES!!!
    I just installed my ORD shackles and new BDS 6" springs. My shackle is in the unloaded position meaning the bottom of it leans toward the front of the truck. I want to move my shackle up in the frame to set the correct angle, but since I just bought the ORD stuff I don't want to waste it. Has anybody used ORD shackles and moved their shackle mount foreward in the frame with good results? I'm a machinest so it would be easy for me to make my own custom shackle, I just don't have the time or enough 3/8" steel at the moment to make my own. I'd also appreciate some pictures of your custom front shackles so I have an idea of a GOOD angle compared to a bad one. Thanks guys /forums/images/graemlins/bow.gif (hopefully this post will show up in search for someone else someday /forums/images/graemlins/whistling.gif)
  2. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Tim (84 Chevy K10) should be able to help you on this. I think he did his not too long ago.
  3. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I've seen a few guys remove the rivets on the shackle hanger in the frame and then move it forward using the rear holes of the hanger in the front holes of the frame. Basically just moving it forward a couple inches and using the existing hole for location. Maybe they were only using one of the existing holes. I think most times people are having to use really long shackles. But then I've also heard of people using factory shackles with some success also.
  4. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    I've been staring at it for days wondering how to fix it without adding a mega long shackle or moving that end of the spring down more than it has to be. I've got some 2" extended shackles, but they have a bar welded in that would hit the frame under compression. I'd really like to stick with something simple and proven.
  5. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    The only other thing I can think of is to build a hanger that sits on the bottom side of the frame rail. Problem their is your gona get a bunch of lift out of it. Somebody on this board ended up with like a 7" shackle or something and i guess I would consider that mega long. I guess you could stay with a shorter shackle and put a bumpstop in to keep it from bottoming out. How about and this might sound crazy but notching the frame for compression? I'm not saying just cut a chunk out but more building the bottom lip of the frame all over again with a hump in it? /forums/images/graemlins/screwy.gif
  6. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    Like the "C's" mini-truckers use to lower their trucks in the back? I kind of like that idea but it's a lot of work for a shackle.
  7. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I guess I'm not familiar with anything minitruckers do so I've never seen the "c's" you refer to but I think we are on the same page. If done right I don't think the structual impact on the frame would be much at all. The only thing that would really change is the height of the channel right where the notch is. This would have the effect of being able to bend the frame in the vertical easier which sucks but you could beef it up a little to ensure that wouldn't happen.
  8. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    It's still a lot of work and would require me to box the frame in that area... not that I don't want to box it already. I'm just looking for something requiring a little less work since I have too many other projects at the moment.
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
  10. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    3 times it was. The biggest problem I had was taking shots in the dark about how long the shackles should be before I actually busted out the tape measure and figured it out the right way. Coulda saved myself alot of time and effort by doing that the 1st time.
  11. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    Thanks guys /forums/images/graemlins/thumb.gif I'm going to start working on the front shackle soon and the rear in a week or two. What size hole saw did you use for the frame? I don't have any so I'll need to buy one. /forums/images/graemlins/rolleyes.gif
  12. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I used a 2"
  13. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I used a Hypertherm PowerMAX 900 holesaw. /forums/images/graemlins/bow.gif /forums/images/graemlins/pimp1.gif
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    http://community.webshots.com/user/tim84k10
    Click on, "Got shackle angle"
    As to the tape measure method, I'm glad you like it guys. /forums/images/graemlins/thumb.gif I can flex my springs into negative arch without the spring eye hitting the frame. /forums/images/graemlins/waytogo.gif
