front shackles
Discussion in 'The Garage' started by BIGBLUEBOWTIE, May 11, 2005.
  1. BIGBLUEBOWTIE
    BIGBLUEBOWTIE Newbie
    May 9, 2005
    4
    Wisconsin
    I'm planing on doing a 52 in. spring swap and I want to make my own shackles. What grade of steel should I use and should I temper it?
  2. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Go with 3/8" thk. x 2" wide cold rolled and it'll be plenty strong. Do the 9/16" bolt upgrade too. Might as well while your in there. Easy enough to do too.
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Just currious was there a factory application for the bushings and sleeve(shackle and frame) that would accept the 9/16" bolts?
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    You just drill the bushings out to 3/4" holes and use 3/4" .090 wall steel tube as sleeves.
    Harley
  5. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    I got 2 "main eye kits" from ORD for my front spring eye bushings... and they came with 9/16" Grade 8 Greasable bolts, and the bushings have an extra wide shoulder to compensate for putting a narrower rear (52") spring in the wider spring hangers up front.
  6. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    my front shackles are CNC machined from a piece of 5/8" cold rolled steel. They are machined w/ a built in spacer for my 52's, and I forget if my bolts are 9/16" or 5/8", but I know that i don't run the steel sleeves in my bushings... all that those are there for is to keep you from over tightening the bolts
  7. BIGBLUEBOWTIE
    May 9, 2005
    4
    Wisconsin
    theres a lot more to this spring swap than i thought. What is involved in the crossover steering thats got me a little worred I'm on a tight budget
  8. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
  9. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    ^ What he said.
