Front Shackles
Discussion in 'The Garage' started by Bubba Ray Boudreaux, May 3, 2006.
  1. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Does anyone sell aftermarket shackles using a 7/16" bolt hole for the spring side of the shackle??????????????????
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    blackwidow and diy4x should both be ready to help ya.
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    mind if I inquire as to why you'd want to do that when people have been known to break 1/2" bolts?
  4. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    :eek1: :eek1: :eek1:
    Spring bushings are the same size as stock and I really don't want to be messing around trying to find the bushings to jump up a bolt size.......................
  5. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    I'm pretty sure that ORD will sell you just the bushings you need, as a separate part. You don't have to buy the whole kit, and it should be fairly inexpensive. I wouldn't want to mess with the stock bolt size. I bent them when I had open diffs and 31's. By the time I went with 36's and wheeled once, they were done for. I don't even like the idea of them in a stock rig.
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I wouldn't worry extremely about 7/16" bolts,(though I would worry too) but you plan to jump don't you? Air under the tires is the hardest on a suspension...
  7. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    I'm using Grade 12 bolts. No problemo:D
