front shackles
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by coopertwpk, Mar 18, 2000.
  1. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    This is kblazen my hard drive decided to go south so now im back .the update on front shackles, well so far ive discovered that my blazer has 7/16 upper bolts and 9/16 lower bolts and 9/16 drill bits are really expensive amazinzingly,so my question is how can ORD say their shackles have 1/2 bolts grade 8 when my lower one is 9/16 and grade 8 from GM?Ok now is the info I need if someone wants a set I need the length they want centerline hole to hole bolt size(earlier models seem to be 4" and 1/4 thick) mines an 88 its(center is 4 1/2 and almost 3/8 thick) the ones ive made are 5 on center and 1/2 thick.
  2. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    Sounds like somebody drilled out your bottom bolt. Never seen one 9/16" from the factory and I have been under allot of K-5's
    Depdog
    <font color=blue>"Lead, Follow, or BECOME the Trail"</font color=blue>
