front shackles
Discussion in 'OffRoad Design' started by coopertwpk, Dec 26, 2000.
  1. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    I just wanted to know do you have shackles with the 9/16 bolt holes for newer 88/91 blazers and do you have greaseable bolts this size, i already have new bushings installed but would like the greasable bolts.
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Usually with the 88-up we put the standard shackle kit on. It' uses a smaller bolt in the bottom, but you get more urethane around it, so it helps the durability of the bushing a little. The shackle length doesn't change on a 88-up, but it gives beefier plates and the bigger upper bolt. We do have a 9/16 x 5 greasable bolt that you could put in as a direct replacement, no problem.
    SW-ORD
