Front shackles
Discussion in 'The Garage' started by conoverbandit, Nov 25, 2003.
  1. conoverbandit
    conoverbandit 1/2 ton status
    Jan 23, 2002
    452
    Conover N.C
    Is it possible to make your own front shackles using 1/4 thick flat plate steel?
    Also what would be a good length when using 52" front springs. Thanks,
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yes it is, I made mine.
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Not from 1/4", I would use 3/8" for significant off road use. Mine are 7.5" center to center and 2" wide. But, 7.5" will be too long for a standard spring pack. Seems like 5.5" is about right, but measure the stock spacing and add about 0.5-1.0 inches (CL to CL) to get a good length.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I think I added 1". Someone check their rig out and I'll measure mine.
  5. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    use 3/8"
    mine are 7" center to center. that was what it took to get the fords enough to move.
  6. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,609
    559
    Wasilla AK,
    I made these for my buddie there 3" longer than stock so the give 1.5" off lift I made mine from 4130 3/8" thick 2" wide flat bar stock I was going to put the tubing between the 2 halves like daystar shackles have but sway has not been an issue it actually drives better than it did with the stock skackles there plenty strong as well we've jumped this blazer a few time testing them and then checked them with a precesion straigt edge and the have not bent one bit /forums/images/graemlins/thumb.gif
  7. yellowK20
    Dec 26, 2002
    7,609
    559
    Wasilla AK,
    mine are 7" center to center also the entire shackle is 9" long
