front shaft lube???
Discussion in 'The Garage' started by johnathan, Oct 5, 2005.
  1. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    How do you lubricate the front cv shaft? 84 blazer 208 stock shaft :confused:
  2. mtnman
    mtnman Scrap metal fabricator Premium Member
    Sep 8, 2005
    2,087
    31
    On the farm , Missouri
    Drive shaft lube
    There is an inverted cone looking grease fitting in between the joints. The best way I have found is to remove the shaft to access the fitting and use a needle tip grease adapter (available at stores such as NAPA) I'll look up the part # and PM you :D
