Front Shaft Pics
Discussion in 'The Garage' started by BDAMNRZ, Apr 30, 2007.
  1. BDAMNRZ
    BDAMNRZ 1/2 ton status
    Aug 9, 2006
    124
    Chesterfield, VA
    Got the front shaft almost ready to bolt back in. I didn't measure the angle but it will droop a lot without binding. What do you guys think obout the home brew? The last one is of the xovee I just finished up.
  2. 01maroonz71
    01maroonz71 1/2 ton status
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    looks good. are those blocks in the front, or big ass zero rates???
  3. BDAMNRZ
    Aug 9, 2006
    124
    Chesterfield, VA
    It is a 1" zero rate that is milled to 8*. It's 1" thick after milling. It looks huge huh.
  4. 01maroonz71
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    yeah it does....haha. scared me there for a minute. looks good man, get them headers wrapped or painted with something, everything looks so clean/good/new/shiney, they stick out like a sore thumb. :)
    nice shaft.
  5. BDAMNRZ
    Aug 9, 2006
    124
    Chesterfield, VA
    Yeah I know. It has got a really worked over 406. Those headers are 15/8 primaries which do not let that motor breathe the way it should. They wont be on there too much longer. That is the reason I have not done anything with them. I should have some video of it on here in the next couple of days. Or atleast it idling hahaha
  6. twoslo4five0
    twoslo4five0 3/4 ton status Premium Member GMOTM Winner
    Oct 5, 2006
    6,615
    71
    Living in a dump, VA
    what cv joint is that???
  7. 85mudbogger
    85mudbogger 1/2 ton status
    Feb 5, 2007
    226
    missouri
    looks to me like your boltin that up to a np208 correct?? looks good
  8. BDAMNRZ
    Aug 9, 2006
    124
    Chesterfield, VA
    Nope, that flange is going to a 205. Keep on guessing. The home brew is equal to a lot of Budweiser, some round stock, some mig wire and a whole bunch of brainstorming on how to avoid a $700 check to High Angle Driveline
  9. Cajun4x4
    Cajun4x4 1/2 ton status
    Oct 17, 2005
    889
    Lafayette, LA
    old axle shafts?... 1410? 1480?
  10. Xtremegmc80
    Xtremegmc80 1/2 ton status Premium Member
    Mar 19, 2007
    1,976
    14
    NE PA
    what u have? new process 205?
  11. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    ill guess:
    you used a 1" driveshaft spacer (ive got one of those in my pile of parts) as a flange and welded the yoke to it. is that 1350 or 1410?
    has me thinking bout welding a 1480 yoke to my spacer hmm
  12. BDAMNRZ
    Aug 9, 2006
    124
    Chesterfield, VA
    Bingo!!!! Instant high angle..... Now we will see if all that work is worth it. The one in the pics is d44 stuff. If I start to pop those I will step up to 60 parts.
  13. BDAMNRZ
    Aug 9, 2006
    124
    Chesterfield, VA
    Whatever the axle shaft joint stuff is. Arent they some kind of x joint or something?
  14. twoslo4five0
    Oct 5, 2006
    6,615
    71
    what did you do about the splined end were the axle yoke goes in???
  15. BDAMNRZ
    Aug 9, 2006
    124
    Chesterfield, VA
    I used the same shaft I had made at Fleet Pride. Wacked off the end at the tcase. Turned down a d44 axle shaft to fit inside the tube. Then took the stock 205 flange and made my own adapter to fit it. With a through hole in the center for another d44 yoke to fit into. Then ran a weld around the outside and inside
  16. BDAMNRZ
    Aug 9, 2006
    124
    Chesterfield, VA
    Here are some pics of just the flange and the yoke
  17. twoslo4five0
    Oct 5, 2006
    6,615
    71
    i got the same basic principle but im going with a square driveshaft :D
  18. BDAMNRZ
    Aug 9, 2006
    124
    Chesterfield, VA
    That should work too, I would ahve but this is on the street a lot. Give me a shout twoslo if you need some help with that. Or come over and check out how mine is working!!
  19. twoslo4five0
    Oct 5, 2006
    6,615
    71
    sweet ya we were gonna have a meet and greet last weekend but it bomed...we are gonna have one next month hope you can make it!!!
  20. thatK30guy
    Jan 12, 2001
    32,076
    55
    Hey! Those zero-rates look familiar! Glad to see they're being put to good use! :waytogo:
