front shaft?
Discussion in 'The Garage' started by bajaviking, May 11, 2005.
  1. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    Is the front shaft from a Blazer with a SM465/NP205 the same as the front shaft from a Blazer with an auto 350/NP208
  2. dyeager535
    26,975
    What year 465/205? Different length based on the year. :(
  3. bajaviking
    Apr 10, 2002
    752
    Baja
    I want to use the shaft from an 82 which has 350/NP208 for my 86 which has 465/NP205.
  4. dyeager535
    26,975
    Probably get better responses later in the day, but hopefully this helps someone compare to a known shaft length...the later (32 spline) 465/205 adapter adds 3 inches to the front shaft length over an earlier 10 spline combo.
  5. bajaviking
    Apr 10, 2002
    752
    Baja
    Sorry, I'm a dumbass, forgot to mention that the 465/205 combo that I have in my 86 Blazer is out of a 78(I think) Blazer, it's the old 10 spline style.
  6. dyeager535
    26,975
    Well, if thats the case, aren't all 208 shafts "CV" style, and all 205's prior to '80 u-jointed shafts?
    In any case, from my experience, the auto trans (208 and even 203's I checked on) shafts all seem to be too long to fit the later 465/205 setup, and that means the earlier 10 spline stuff would need to be 3" shorter than what is already too long to fit on the 32 spline setup.
    I'm going to stop contributing lengths now, I don't have the specs of exactly what you are looking for, I'd hope someone does. :) Is there a listing of the stock front shaft lengths (stock) that anyone is aware of?
    We could start one...I've got both 10 spline 465/205 and 4L80E/205 shafts that I could measure.
