Front Shims!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dansblazer, Apr 13, 2005.
  1. dansblazer
    dansblazer Registered Member
    Sep 17, 2004
    32
    Oshawa, Ontario
    Hey Guys is there a problem adding shims to the front end. I need to add about 2 degrees maybe 4 degrees to compensate for the extra length in shackles. 2 or 4 degrees will bring the pinion angle back to where it was.....
    Regards Dan
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    no issues wiht that at all on a 10 Bolt. On a chevy D-60 it can get a little tricky around and above 4deg. You need 3 shims for that. I or someone can explain if you have a D-60
  3. dansblazer
    Sep 17, 2004
    32
    Oshawa, Ontario
    Thank You for the Info
    I thank you for the fast responce....Its amazing I also belong to a Canadian Site and I have not yet receive or gotten any information as fast or as accurate as I am getting on CK5.
    This is a 10 Bolt that I will be shimming and again Thank You.
    Regards Dan
  4. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    just make sure the spring pin passes fully through the shim and engages the perch completely on the other side
  5. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    I'm curious how you do it with a D60 and the three shims.
    Thanks,
    Eric M.
  6. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    I think two would mount between the spring pads and springs and one between the spring and spring plate on the passenger side (so the nuts mount flush to the spring plate).
  7. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    yup
  8. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Thanks,
    Eric M.
