Front Shims?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SuperUnknown, Sep 14, 2001.
  1. SuperUnknown
    SuperUnknown 1/2 ton status
    Feb 8, 2001
    165
    Prince George, British Columbia, Canada
    I just installed some BDS 4" springs in the front of my '88, and will soon be installing some ORD extended shakels. The problem is that my front drive shaft can no longer be connected. Will some shims fix this? if so what degree? ...and also, will my front shaft need to be lengthend? P.S. The T-Case is dropped, if that makes a difference.
    It's ok to love your truck.
  2. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    If it wont reach now... no the shims wont help... it may "reach" but it wont be safe at all... you'll need to get it extended... about 130 bucks... my rear one... I thought was long enough... wrong.. popped out the first time I locked the brakes on the rear... in the middle of traffic... not cool...
    [image]http://www.inhomenetworking.com/images/littleblue.jpg[/image]See me at <a target="_blank" href=http://www.inhomenetworking.com/78jimmy.htm>http://www.inhomenetworking.com/78jimmy.htm</a>
  3. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    How or why cant it be connected? You sorta left that detail out. Is it rubbing on the exhuast pipe or what?
    "you know... the guy with the BAD A$$ spring perches!!![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  4. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    Yeah, why can't it be connected? I have a 4" lift on mine and never had any problems with the driveshafts.
    <font color=red>"Thank you for pot smoking."</font color=red>
  5. SuperUnknown
    Feb 8, 2001
    165
    The front diff is now pointed down and away from the T-case and the front shaft can't reach it in it's current position.
  6. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    If its just too short, you can buy a 1" spacer for the top. They used to be around $40 (5 years ago).
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  7. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    I have a 3/4" spacer that I used way back when, cost me $65 at the time, supposed to help lifted trucks clear the ex. y-pipe. It's up for sale if any wants.
    Mike
    You call that dirty!?
