Front Shims
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chvyhs, Jan 19, 2002.
  1. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I put some 3deg shims under my front spring packs. The problem is that the spring center bolts don't go through the shims and into the spring perches. Is this a problem?
    <a target="_blank" href=http://community.webshots.com/user/chvyhs>WebShot Pics</a>
  2. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    I would think so, the center bolts help guid the axle onto the springs and keeps it centered. I'm not sure what the fix is.
    Sooooo......
    TTT
    <font color=white>.</font color=white>Eric
    <font color=white>.</font color=white>Twizted
  3. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Yes I would call that a problem. I put shims into my last rig and they broke and part of it popped out. I will never use them again. Are you having caster problems w/ lift springs? I have a shim built into my 6 " springs. I will be removing it. It is killing my caster and makes my Blazer wander.
    If ya can't stop.......Smile as you go under! [​IMG]
    PIC of mine from flblazers site<a target="_blank" href=http://www.flblazer.alloffroad.com/photo3.html>
    GO</a>
