Front slip joint
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Derf00, Feb 17, 2001.
  1. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Okay guys, this may be one of those stupid questions, but I need some info. I was under the Jimmy today and noticed that the front slip joint has some "slop" in it, a lot more than the rear. What is normal? Is there anything to rebuild?
    Any info would be appreciated.
  2. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    Sounds like it is worn out. When you ride in 2WD for a long time the shaft doesn't turn and is always rubbing in the same place. This is why it wears faster than the rear, which is always turning.
    Jim '80 GMC
    Freedom First!
    <A target="_blank" HREF=http://www.bigjbear.coloradok5.com>http://www.bigjbear.coloradok5.com</A>
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    A driveshaft shop can install a new slip joint in your shaft. Keep it greased.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  4. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    give me a call i'll be happy to give a quote- 530-872-5725 - high angle driveline - jesse
  5. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    If I ever get this truck to pass the smog test I'll be taking mine to a driveshaft shop. I know I need the front slip joint replaced and I want to get the angles checked before I take it from CA to OK this summer.
    Smitty
