Front speaker locations
Discussion in 'Audio' started by 91K5, Dec 16, 2001.
  1. 91K5
    91K5 1/2 ton status
    Jul 5, 2000
    185
    Wichita, Kansas
    Well my head unit finally fried my last front dash speaker, so now it's time to upgrade, but I'd like to get something bigger than 3 1/2" for the front. I test drove an 85 K5 before I bought my '91, and someone had mounted speakers in the front doors. I know I've heard some people say this cant be done with power windows, but the '85 had them, and about a 5.25" speaker mounted in there. Has anyone mounted speakers in the doors with power windows? Also, what about mounting them in the kick panels? I've seen this done but dont know if its a bright idea or not. I dont want to spend the $200 for the pods, so that's out of the question. Any ideas or help would be greatly appreciated, thanks!
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Put them in the door right where the pouch is. Use the 5.25"
    86Jimmy 4"&35"MTRs,87 burb 4"&33"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. 91K5
    91K5 1/2 ton status
    Jul 5, 2000
    185
    Wichita, Kansas
    OK, so if I went with some 5.25" components where would be a good place to mount the tweeters for the best imaging?
  4. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    theres a carpeted panel below the plastic door panel or bare metal if its a plain truck.remove that,trace it onto a peice of 3/4 plywood and cut it out.cut your speaker holes in the plywood tward the foreward edge of the door,and cut holes to match in the door.cover panel with carpet that matches interior color.screw it to the door.the thickness of the plywood should solve any chearence problems.another good idea is to use the foam inserts behind the speaker,because the doors are not watertight.you can get them at most stereo shops.if your on a budget,a good pair of 6x9's are hard to beat in the kick panels.good luck,rob
    eatin'fords and shittin'dodges
  5. 91K5
    91K5 1/2 ton status
    Jul 5, 2000
    185
    Wichita, Kansas
    Thanks for the help guys, saved me 200 bucks for the qpods [​IMG]
  6. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Check my set-up...I have power window's and I have not had a problem with my speakers.
    <a target="_blank" href=http://www.community.webshots.com/user/vwryda>The Ringmaster</a>
  7. BPS
    BPS Registered Member
    Mar 24, 2001
    28
    Sooke, BC, Canada
    hey ringmaster - what size ore those speakers?
    1990 K5 with chalet type camper
    4 inch lift, 33x12.5 tires
  8. jekbrown
    May 19, 2001
    45,032
    366
    Vancouver, WA, USA
    if u are gonna mount some speaks waaaaaay down on the door (on that carpeted panel thingy for instance), better make sure they are water proof....otherwise the next water crossing with the local 4x4 club wont be quite such good times. &lt;sploosh!&gt; =)
    Jason
    See the on-going build up of my '85 Jimmy! <a target="_blank" href=http://community.webshots.com/user/jekbrown>http://community.webshots.com/user/jekbrown</a>
  9. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> Post pillars !
    L8r,
    . Riz . <a target="_blank" href=http://www.geocities.com/rizmonkey>www.geocities.com/rizmonkey</a>
    <font color=purple> BOW CHICKA BOW WOW !
  10. UseYourBlinker
    Jun 7, 2000
    11,117
    Updated my site (Link Below) of my speaker pod's that house 6 1/2 speaker's. Also took some measurement's!
    Eric
    from Freekmont,CA.
    <a target="_blank" href=http://www.community.webshots.com/user/vwryda>The darker side of nonsense...</a>
  11. maxq15
    maxq15 Registered Member
    May 16, 2001
    44
    Miami, Florida
    Hey Blink,
    Why did you decide to put your compnents up high on the door versus down low? How much depth is there from the door panel itself to the first thing it would hit inside the door? I have some Boston's that are pretty deep for 5'1/4's and am wondering how thick I would have to make my "pods" if I went that route.
    Those who think money can't buy happiness don't know where to shop.
  12. UseYourBlinker
    Jun 7, 2000
    11,117
    Cause you can hear them better higher up. The depth I would say close to two inches. So in all with the speaker mounted on the board,you have more than 3 inches for clearance for the speaker magnet,and some room for the wires.
    Eric
    from Freekmont,CA.
  13. 91K5
    91K5 1/2 ton status
    Jul 5, 2000
    185
    Wichita, Kansas
    Thanks a lot Blinker for the measurements and pics of your setup, I'm going to do something close with mine and ditch the dash speakers.
  14. UseYourBlinker
    Jun 7, 2000
    11,117
    No problem... I'm sorry that it took so long to post!
    Eric
    from Freekmont,CA.
