Front Speaker(s)
Discussion in 'Audio' started by 87K54WD, Apr 4, 2000.
  1. 87K54WD
    87K54WD 1/2 ton status
    Mar 23, 2000
    105
    Texas
    Was just curious here, I currently have an AM radio only in the K5 and seems like I only have one speaker (in the middle of the dash). I can see the speaker pin holes for the right and left on the dash but no sound comes from there. Do I just have one speaker then or did the AM radios just use the center speaker? If I do just have one speaker, could I put two more on each side ... again I have the pin holes, which leads me to believe that speakers are suppose to go there, as well as the wiring should be there too???
  2. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    the speaker in there is like a 5x8 in size only one. I have cut some ABS before or some back strapping and mounted to 4" speakers in there. Getting your hands up that high in your dash is funnnnnn
  3. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Yes you can add the speakers at each end of the dash. I believe your refuring to a 81-91 model of K-5. If you don't have the mouning plates in there go to a junk yard and get them. Remember which one goes on with side. They aren't that hard to put in just take out the dash and put them in from the top. and your done. You'll have to run wires to the radio unless your lucky and find the ones in the harness. wire to radio. With it being AM only it is most likely it is going to be mono only so no stereo seperation.
    C'moe
    <font color=black>the blazer is "Back in Black"
  4. **b**
    **b** 1/2 ton status
    279
    KIllington, VT.
    you can have my old dash speakers!
    (a joke)[​IMG]
