Front Speakers
Discussion in 'Audio' started by Cusm, Feb 25, 2000.
  1. Cusm
    Cusm 1/2 ton status
    Feb 25, 2000
    360
    OK
    I need ideas for frotn speakers. I have an '82 and the electric window motor or regulator is right where speakers would go in the doors. I need a fairly inexpensive alternative, I no longer have the want/need for a $3000 system. Any ideas?
  2. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    I put mine in the front kick panels. You have to cut the plastic and some sheetmetal but it works fine. Good luck!
    Esteban[/b]
  3. 1bad2
    1bad2 Registered Member
    65
    Jacksonville, FL
    I have an 88 that came with the 3.5" speakers in the dash. I replaced these with 3.5" Infinity's, which required no cutting or mods so it looks super clean and sounds great.
    Curtis
  4. KGBLAZER83
    KGBLAZER83 Registered Member
    16
    sanat barbara california
    ok another idea, you can make some boxes small of course, and secure them right under your seats facing out. unless you are adjusting your seats a lot. my friend did this and they look and sound great i think he used pioneer 51/2 inch.
    blaze on!!!!!
  5. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    kick panels dude. simple to cut and then mount. looks and sounds fine.
    shaggyk5
    aint nuthin in the world like a heavy chevy
  6. Cusm
    Cusm 1/2 ton status
    Feb 25, 2000
    360
    OK
    Shaggy, Did you angle the speakers or just mount them flush?
  7. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    kick panels are the choice location. no angle necassary. i also have infinity tweets in the door, in front of the power window controls. adds some highs, without alot of power.
    <font color=purple>delta9blazer</font color=purple>
  8. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I cut a 1/2 inch piece of ply wood out to fit the bottom part of of my door exactly then i used 2X2's to "box" in the front half and out another piece of 1/2inch ply wood cover it. I made an enclosure for my mids that did not cut the door or door panel at all. I used a jig saw to cut the rounded corners and a wood rasp to make things look good. I then carpeted the paned with some color matched carpeting ( you know that crap from wal mart ) and attached the home made panel to the door paned with 1/2 inch screws put it all back to gather. It was for midrange only, there was no midbass at all so 800 hz and up was good to go..
  9. Cusm
    Cusm 1/2 ton status
    Feb 25, 2000
    360
    OK
    Hey 85Mouse, Do you have any pictures? I have toyed w/ an idea similar to this. Q-forms makes some plastic housings that do this, but they want $200 a pair. Which is probably more than I will pay for the speakers that would go in them.
  10. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    Im sorry I dont have any pictures...the q-form panels come gel coated I think so you have to paint them..and I dont like the idea of speakers in the kick panels personaly. Somthing else I did to install the door speakers was to use the carpeted bottom part of the door as a template and cut out a piece of 1/2 fiber board to match..I fit a 6 1/2 MB Quart woofer in it (you could prob install a 10" sub if you wanted!)..I had to trim the metal in the door a little bit, I used a dremel tool and zipped right thru it. I put on a baffel from crutchfield to protect the speaker from the elements, and I am not kidding it thumped!! This is when Rockford Fosgate was the COOLEST thing EVER and you could not buy the amps at wal mart like you can now, I had a punch 100 running the Quart separates and IT sounded unbelievable..Low bass down to 60 hz, I clipped 1 tweeter and that was the end of it all...All you need is a jig saw, carpet, and that areosol adhesive. I dont mean to go on and on but I was RIPPED OFF one time when I was just a wee lad, a local install shop did this same install on my 1st vehicle a 91 s-10. They charged me 80 for the panels, 75$ for the install and I supplied the speakers...This will cost 30-40$ at the most if you do it your self..let me know if there is any thing I can help you with
  11. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    I have put 5 1/4" in the kick panels before and 6 1/2". WOW there is some serious steel to cut in there to. Q forms I think still makes panels that will fit. DOOR location is by far the best sound, some problems with imaging though, but they rock, unfortunately the motor is there for the windows ugh. Good luck
