Front spring bolts rusted or bound to sleeves
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sarasotausmc, Mar 23, 2006.
  1. sarasotausmc
    sarasotausmc 1/2 ton status GMOTM Winner
    Dec 16, 2003
    769
    Jacksonville NC
    Already did a search, didn't find the answer after about 20 mins of looking....
    Putting on my new front springs. Can't get the bolts (either front or rear) out of the sleeve on one leaf spring. No tension on the spring. Tried BFH, and then B'er FH, nothing. Probably ruined the threads already. PB'ed them beyond reason tonight, will try again tomorrow. If that doesn't work, will just cut em out. What size are the front and rear bolts on a stock 87 Jimmy front leaf springs? Figure I would try my luck asking before removing the other spring bolts and taking them down to the auto shop to match em up.
    The other ones came out easily BTW.
    If there are any other tricks I could try, would appreciate the input too. Thanks.
  2. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
  3. sarasotausmc
    Dec 16, 2003
    769
    Jacksonville NC
    looking like it
  4. sweetk30
    Nov 1, 2004
    25,549
    543
    horseheads , ny 14845
    :weld: :grind: :hack: :1zhelp: or a real good air chisle with concaved button head so it will stay on bolt.
  5. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    When I pulled the rear springs off my '87 C10 donor truck, I used an air hammer with a pointed-punch chisel to push the shackle bolts out. I used a 1/4" drillbit to make "cups" in the threaded end of the bolts, about 1/4" deep, so the punch wouldn't skip off the bolt.
    Still took about a minute of hammering at 110psi to get them out due to the rust...
  6. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    I just got done contending with some 30 yr old control arm bolts on a 442 yesterday with all the same issues... what works well is to thread the nut back on some them use a round, cutoff, whatever, air hammer bit in it.. the nut keeps the bit captured giving it a centering capabilty..
  7. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    My front ones did that too. I used a socket on the head turning it with a breaker bar, at the same time have someone hit the other end with a BFH. oh and plenty of Mdew. good luck
  8. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    balljoint press and some beernuts!
  9. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    i just got in there w/ an angle grinder.. .cut the bolt on both ends so i got the spring out.. and the bolt was just rusted frozen in there... so then i took a 20ton bottle jack press and pressed the whole bushing thing out.. replaced it w/ a 20buck one from napa.. good to go and saved a lotta work.
  10. sarasotausmc
    Dec 16, 2003
    769
    Jacksonville NC
    thanks, got the cutting done with the grinder.
  11. bluehen
    bluehen 1/2 ton status
    Nov 11, 2004
    215
    DE
    Glad you got it done. I used the cut-off wheel too. BTW - they are 9/16" bolts.
  12. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
  13. maynardogle
    maynardogle 1/2 ton status
    Mar 7, 2005
    159
    Orange County, CA
    Now i REMEMBER WHY i MOVED TO cALIFORNIA....
