Front spring + Bushing width??
Discussion in 'The Garage' started by Masher, Jun 21, 2003.
  1. Masher
    Masher 1/2 ton status
    Mar 7, 2002
    123
    SW Michigan
    After I put the poly bushings in my front springs they end up being a little less than 4" wide. Now the hangers and shackles are only about 3.5" wide. Should I just pound the springs in there or do I have the wrong bushings??
  2. Masher
    Mar 7, 2002
    123
    SW Michigan
    /forums/images/graemlins/1zhelp.gif
  3. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    How wide are your front springs, 2.5", 3"? When I put my Skyjacker springs on I also bought some Energy suspension bushings for the stock springs. Well, turns out the stock front spring is 3" and the Lift spring was 2.5" So, I have to get some wider bushings. Maybe you have the wide bushings and a 3" spring.
