Front spring center bolt {pin}
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xflatrater, Dec 29, 2003.
  1. xflatrater
    xflatrater Registered Member
    Nov 28, 2003
    65
    Shamong NJ
    Can someone measure the center bolt if you have an old set of springs lying around? I need the bolt diameter and the pin diameter for custom steel caster shims.
    Thanks!
  2. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
    i have an old stock set from my 86. the center pin dia is 9/32nds. the nut is 1/2 inch and the the center pin head is also 1/2 inch...
  3. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    3
    Houston, Texas
    Mine are all 3/8" fine thread and take a 9/16" socket. Just worked on the springs about 2 hrs ago /forums/images/graemlins/grin.gif
    A 3/8" socket hd cap screw is usually what works, someone corect me if Im wrong.
