Front spring hangars worn out
Discussion in 'The Garage' started by Cricket, Aug 12, 2006.
  1. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Anyone else dealt with worn out front spring hangars. That'd be the rear mount on the frame for the front springs. Mine are oblonged and the shackle pops over any significant bump, even with good bushings. I know LMC carries replacements for 80.00 a pop but that is a bit steep for my wallet. Anyone else fab these or did you just get a set used?
  2. Gravel Maker
    Gravel Maker 1/2 ton status Vendor
    Feb 6, 2006
    2,570
    23
    Sacramento, CA
    Lots of hangers out there.....
    And not too expensive, hint, hint....
  3. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Hint, as in you make it? :dunno: I don't remember seeing it on your site.
    Here's a link to the LMC catalog page for reference. Part #19.
    http://www.lmctruck.com/icatalog/cc/0126.html
  4. grape
    grape Registered Member
    Mar 10, 2005
    27
    texas
    i welded mine up and re ground them by hand......
  5. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Brent from Trople Motorsports makes new ones that hold 1-1/2 bushings instead of the anemic stock 1-1/8 bushings. This allows the use of a bigger bolt (9/16 instead of 7/16) without losing any bushing material. Adds a lot of strength if you ask me, and you probably wouldn't have to be worrying about this ever again.
    Here's the thread
  6. Cricket
    Nov 29, 2004
    8,224
    Colorado
    I appreciate the heads up but the link takes me to an HTTP page.
  7. RGV72BLAZER
    RGV72BLAZER 1/2 ton status
    Jan 23, 2006
    2,425
    Edinburg*San Bene*Online-The Real South Texas
    ORD makes some...but they're a bit on the steeper side. ~140 with bushings. beefy as hell tho.
  8. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Here's the thread
    Sorry, I screwed it up. Fixed it for ya.
