Front spring hanger bent!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddin4fun, Oct 29, 2001.
  1. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Yes! Carnage! Although, I have no idea when it happened! [​IMG]
    anyway, it's the right front front spring hanger that's bent towards the outside (like from flexing). Is there a way to make them stronger?
    Peace and stuff [​IMG],
    Muddin
    <a target="_blank" href=http://www.geocities.com/muddin4fun79blazer>www.geocities.com/muddin4fun79blazer</a>
  2. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Buy heavier duty ones from ORD or go to the local metal fab shop and have them make new ones out of thicker/stronger material. They should only charge a few bucks to do this. The only extra $$ you may have to spend is on longer bolts depending on how much thicker they make them and how many threads you have exposed now.
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot>http://coloradok5.com/gallery/Leadfoot</a>
  3. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    I guess you could weld in a 1/4" sheet to brace it...like at the front opening end.
    Pic of my truck Before N' After
    <a target="_blank" href=http://coloradok5.com/gallery/BeforeNAfter>http://coloradok5.com/gallery/BeforeNAfter</a>
  4. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    I'm concerned the bolt is broken...if just one ear of the hanger is bent out I can't see that happening with an intact bolt. If it's the whole hanger that's bent out then I'd suspect a few rivets let go.
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    I agree with Rene.... Might want to inspect them and replace the rivets with Grade 8 bolts.....
    Mike
    <font color=green>"1024x768x256... Sounds like one mean woman."</font color=green>
    <a target="_blank" href=http://www.geocities.com/emmettology101>www.geocities.com/emmettology101</a>
  6. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    The whole thing is crooked. [​IMG]
    Muddin
  7. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    I just went and took a quick look at it. No broken bolts and the rivits are still in. I should get the weight of the truck off it and see if it's loose.
    Muddin
  8. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    The heads of the rivets might still be there...but I'd wager they're busted.
    Rene
  9. Emmettology 101
    May 9, 2000
    8,126
    FL
    Thats from haulin too many potatos!!!!!
    Mike
  10. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    I guess! [​IMG]
    Muddin
  11. Leadfoot
    Nov 28, 2000
    3,112
    Woops, my bad [​IMG]. I though you meant right front, not right front-front hanger. If the rear (of the front) spring hanger is bent, then go with ORD or metal shop, but if it is the front-front hanger, you may have to take it to a place that has hydraulic frame straightening equipment (especially if the rivits are still tight). Chances are if the mount bent, the frame may have tweaked too. Maybe, or maybe not, but they have the tools to figure that out and how to correct it.
