Front Spring hanger problems
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Robin, Jan 7, 2002.
  1. Robin
    Robin 1/2 ton status
    Oct 30, 2001
    184
    Georgetown, Texas
    I was painting the frame on my 72 Blazer (springs off) when I noticed the passenger side front mount (which is a upside-down U shapped stamped extrusion that's riveted to the frame) was elongated vertically. The effect is that, that side sits lower because the bolt rides higher then stock.
    I guess the first question, is what makes this happen?
    Has anyone ever fixed this kind of problem before?
    Does filling the warn part of the hole with weld stick make sense?
    Since it's a riveted piece, it seems like a real hassle to cut the rivets off my truck, then find another at a junk yard, and do the same, then bolt the replaced extrusion on...
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The hole may have elongated because the spring eye bolt may have been loose. Welding up the hole and drilling it back out sounds like a good fix to me.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  3. JMZ
    JMZ Registered Member
    Dec 4, 2001
    73
    Gonzales , Texas
    I made some spring hangers for mine, they turned out really nice. But I would also say that welding and drilling new holes would be a good Idea.
  4. 71RestoRod
    71RestoRod 1/2 ton status
    Mar 7, 2001
    178
    Evergreen, CO
    Did that repair on my Willys. Weld it up, grind it flush and drill it. Works great.
