Front Spring Hangers???
Discussion in 'OffRoad Design' started by backcountry, Jun 26, 2004.
  1. backcountry
    backcountry 1/2 ton status
    May 27, 2004
    916
    Hello all!
    Does anyone know if there is a longer front spring hanger available for a 1973 Chevy K/10 Pickup?
    If so where can I purchase some?
    My goal is to raise the front of my truck a few inches max.
    Thank you!
    /forums/images/graemlins/cool.gif
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I don't know of any, we usually recommend an arched spring for a bit more lift. Typically with up to a 6" lift and even with an 8" it works OK.
    You do have to watch the approach angles with a drop hanger, they could get to be a ground clearance problem.
  3. backcountry
    May 27, 2004
    916
    Thank you Stephen. When I installed my new springs front and rear to lift my truck, the rear is 2" higher than the rear. I do not like the way it looks. I ordered your heavy duty shackles for the front that will give me 1/4", however I still have 1 3/4" to go.
    I guess I will just order new springs for the front unless anyone has any suggestions to make up the difference without to much stiffness.
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Get yourself a set of 1" zero rates for the front also from ORD. That will gain you 1" more of lift in the front giving your 3/4" difference front to trear which really wouldn't be that noticable /forums/images/graemlins/thumb.gif
  5. backcountry
    May 27, 2004
    916
    Cool,thank you!
    I saw them but they looked like blocks so I though nothing of them untill you keyed me in.
    One question though: Will they make the springs weaker being that they are so short?
  6. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    They will have no effect on the springs. They are about as long as the perches that your springs bolt to now.
  7. backcountry
    May 27, 2004
    916
    Thank you! /forums/images/graemlins/thumb.gif
  8. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Well, that was pretty easy.
    Since the zero rates bolt in, they're technically a leaf and won't cause any problems for you other than ubolt length.
  9. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    Another idea would be to swap the rear hangers on the rear leaf springs to the 2 wheel drive type. That would lower the back a bit. Might be a good solution if you don't want any more lift in the front.
    Eric M.
  10. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    You can always make custom dropped hangers, thats what I did.
