front spring lenth? Will these work?
Discussion in 'The Garage' started by BiggerRigger, Feb 12, 2004.
  1. BiggerRigger
    BiggerRigger Registered Member
    Nov 3, 2002
    81
    C.D.A. Idaho
    I have a set of 62" leafs and wondering if I can use them on the front or the rear of my 89 jimmy. The springs are 2.5" wide. Thanks in advance
    Aaron
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    62 are waaaay to long for front use. the stock front springs are 46 or 47. 52s are almost as long as you could go with out moving the shackle or extending the frame forward. i would use them for the rear. i believe you need to move the front hanger forward and the rear back to get the center pin centered in the wheel well.
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Actually to properly locate 52s requires moving the frnt spring hanger, some opt to redo the frame with a new crossmember.
  4. BiggerRigger
    Nov 3, 2002
    81
    C.D.A. Idaho
    Thanks for the quick reply I think I will use these springs for a new dog crap slinger since they will not fit my junk.
    Aaron
