front spring q's
Discussion in 'The Garage' started by dheavychevy38, Apr 12, 2005.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    Ok so i was under my truck today and noticed the front spring rear hanger bolt that goes through the frame broke anyone else have this happen.
  2. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Never seen that happen. Simple fix though, standard bolt you can get anywhere.
  3. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    except i can't get it out so i will get new bushings and make new shackle i went to turn in the shop heard a loud pop thought nothin of it started to look at stuff to do and found that :blush: just wondering if anyone else has seen that.
  4. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    You can't get it out? Try unbolting the other end of the shackles to loosen things up, use a BFH of course. How exactly is it stuck?
  5. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    no the bolt and the steel sleeve are stuck together besides i could use some new bushing so tomorrow i will just use the hot wrench :weld:
  6. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Ah, I see. That'll do it.
