front spring question
Discussion in 'The Garage' started by 86chevybanshee, Jun 12, 2004.
  1. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    i want an 8 inch lift in the front of my truck, but i dont want the stiffness of 8 inch springs, so i was wondering if there was another way of getting 8 without buying 8 in springs, i was thinking 6 in springs with ORD zero rates and then with these shackles http://www.hill4wheeldrive.com/cgi-bin/products.cgi?category=category01&item=5392128774. but then i have to worry about the pinion angle right? any other suggestions, and i dont want to do the 52" swap
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] 6" Suspension lift and 2" body lift. Or you could always just /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif the fenders. /forums/images/graemlins/whistling.gif /forums/images/graemlins/thinking.gif
  3. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    i have 8 in the back, when i bought the truck it had a 4 inch in it, then i did the shackle flip, and i like the 8, now im just looking to get 8 in the front.
  4. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    8" BDS springs which are pretty soft or 6" BDS springs, zero rates, and extended shackles.
  5. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    if i put extended shackels wont it f up the pinion angle?
  6. Highjaxx
    Highjaxx 1/2 ton status
    Apr 17, 2002
    273
    Austin,Texas
    If the shackles mess up the pinion angle you could get angled 0-rates. Tapered(speling??? /forums/images/graemlins/whistling.gif)
    /forums/images/graemlins/doah.gif
    The body lift may not be a bad idea either, I kinda wish I had done one, and as it sounds like this is the beginning of the build it may the best time. I haven't done one, but plenty have and it makes room for drivetrain upgrades later.
    4" springs+2" body+1" shackles+1" 0-rates=8" front
    but
    it will also give you 10" in the back, so you could put 2" lift springs in the back and jam
    lots of options, lots of opinions /forums/images/graemlins/thumb.gif
    Oh ya, then cut the fenders, and put on 42's
  7. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    [/ QUOTE ] with 8 inches of suspension lift you will need new drivelines anyway so that could be addressed at the same time. Also the tapered zero rates would work like mentioned above.
  8. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    hmm. maybe i will put 2 inch blocks in the back and do 6 inch fronts and get a 2 inch body lift. but as u sed if i do 8 inch suspension i will need to extend my drive shafts right? well the back one fits fine but the front is what i have to worry about. but i have an sm465\205 im about to swap in and im wondering if the front driveshaft from the truck now 700r4/208 will be long enough?
