Front spring stop
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by ssls6, Feb 8, 2005.
  1. ssls6
    ssls6 Registered Member
    Jan 5, 2005
    86
    Dallas, TX
    My 72 has a front spring stop bolted to the frame on the drivers side but not one on the passengers side. The stop is located right behind the front shackle. It looks like it limits the rearward motion of the spring eye during flex.
    I need a passenger side stop. Does anyone know where I could find one?
  2. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    Instead of looking for another one (which never existed on the passenger side, BTW) I'd remove the one on the driver's side!!!
    Seriously, if you're modifying the suspension that stop will give you some SCARY behaviors under braking. As the front end dives under braking the drivers side spring is limited by the stopper, but the passenger side continues to compress....the effect is that the truck wants to "turn" sharply to the right....a rather unsettling effect.
    Once I figured out what was happening on my truck, I removed that stopper and from then on my braking was perfectly straight and a lot less "exciting"!!!! :cool1:
  3. ssls6
    Jan 5, 2005
    86
    Dallas, TX
    Thanks. I didn't realize that the passengers side never came with one. I'm learning a lot from this site. I've been into Chevelles and El Caminos for years but this is my first K5.
  4. gjk5
    gjk5 3/4 ton status
    Mar 17, 2004
    5,312
    Grand Junction, CO
    Thanks, I had wondered about that stop and whether removing was OK. (glad to hear it is since I removed it months ago.)
  5. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    I suppose to be "technically" correct, you could spend the time figuring out how far back to move it so that it only works in extreme cases.
    AFAIK, that was part of the retrofit for a safety recall on early K5s. The idea was presumably to hold the spring if the shackles or rear spring bolts ever broke...it would still be a pretty scary stop, but at least that whole side of the truck wouldn't drop completely to the ground!!!! There was also a metal strap welded across the front spring hanger for similar reasons. If you lose that spring mount, you probably also lose your steering since it's connected on that same side......(another reason why you don't see those parts on the passenger side)
    A set of good quality bolts and a set of the ORD HD shackles are probably the better way to go anyway.....
  6. gjk5
    gjk5 3/4 ton status
    Mar 17, 2004
    5,312
    Grand Junction, CO
    Soon to be done along with ORD shackle flip to get rid of my blocks, thanks for the info.
    Sorry for the hijack ssls6.:grin:
  7. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    I removed it and the strap in the front from both my trucks.
  8. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    I had heard a different reason for the spring limiter. I had read that it is called the "Steering Quickener" and was designed to limit the spring during hard right hand turns or large bumps. As the driver side spring flexes the amount of steering wheel turn to keep the truck pointed correctly would increase.
    I could see it being a safety recall as mentioned to prevent a death wobble during a sudden maneuver where the wheel would bounce back and forth in your hands as the vehicle pitched right and left.
    Jeff
  9. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Years ago I read a recall letter from GM over at an old site called blazernet.com
    Someone had posted the actual letter and in 1969 the K5 driver's side front eyebolt was shearing off. The fix was the added 'strap' on the front and the stop on the rear to 'trap' the spring inplace if that bolt was to break. I guess the bolt was undersized or something. There was more to the letter but I can't remember the rest.
    I removed my stop but the front strap is still there. It doesn't get in the way so I just left it.
    Good Luck
