FRONT SPRINGS AND SHACKLES!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MITCH_89', Dec 18, 2000.
  1. MITCH_89'
    MITCH_89' Registered Member
    Dec 7, 2000
    91
    GULF BREEZE, FL.
    WHEN I INSTALL MY FRONT SPRINGS, IF THE SPRING ISNT QUITE WIDE ENOUGH IN THE SHACKLE, DO I KEEP TIGHTENING THEM TILL THEY ARE TIGHT AND BEND, OR ARE THEY SUPPOSED TO MOVE FREELY?
    BLAZE IT UP!!
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Hmmm, I would start off by tightning to the torque setting for that mount. If it still has the side to side slop then something is not right. Call whom ever sold you the parts and confirm part # and or make and modle. Something doesn't seam right............
    Good Luck
    http://www.burt4x4.coloradok5.com
  3. MITCH_89'
    Dec 7, 2000
    91
    GULF BREEZE, FL.
    THAT WAS THE CASE WHEN I INSTALLED MY 3" TOUGH COUNTRY KIT. I SNUGGED THEM UP PRETTY TIGHT, BUT IN ORDER TO GET THEM THERE, THE SHACKLES ACTUALLY STARTED TO BEND. DIDNT SEEM QUITE RIGHT. I WONDER IF THEY SENT ME SPRING FOR A TRUCK INSTEAD OF A BLAZER, ALTHOUGH I CANT SEE ANY DIFFERENCE. BUT IF THEY ARE THE SAME, WHY DO THEY LIST BOTH???JUST SOME THOUGHTS
    BLAZE IT UP!!
  4. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I was always told to tighten them to the point in which the bushings just start to be squeezed, any tighter will make the bushings bind and can hamper the springs from flexing.
