front springs
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 71 Blazer, Feb 17, 2006.
  1. 71 Blazer
    71 Blazer 1/2 ton status
    Jul 16, 2005
    184
    windsor virginia
    I'm am in the process of doing a 4" suspension lift on a 71 blazer. I have the back done and when I measured the front vs the back I have a 5.5" difference, but when I looked at my front springs they are not flat or curved down, but curved up about 2". Is this normal or are they just beat. The front springs have only 2 leaves. If they are not at the stock height I need to know so I can compensate when I order my front lift springs.
  2. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,956
    249
    Released from Pueblo, told I belong in Southpark
    They were designed to basically be flat or with very little arch. Mine were like yours before I replaced. They had a negative arch to them. I would definately go with more lift in back than in front. I went with 1 inch extra and now I wish I would have done 2" I may do a zero rate for an extra inch later. It will depend on if my front springs sag any once I start flexing them.
    I have 6" Tuff country up front and 4 inch ORD shackle flip with 3 inch tuff country in back all ordered thru ORD, along with heavy duty greaseable shackles and lots of other goodies.
  3. 71 Blazer
    Jul 16, 2005
    184
    windsor virginia
    that makes sense. So far I have 95 k5 springs and the ord shackel flip and was wondering why I got almost 6" of lift when I was suppossed to get 4" thought I was lucky. I was going to go with skyjacker or superlift. They seem to have the next softest spring rate as tuff country. I have found that tuff country springs are so soft because they are made of thinner metal and don't last as long.
  4. 71 Blazer
    Jul 16, 2005
    184
    windsor virginia
    What about BDS? I heard they have a soft spring rate. I don't have to put more lift in the front than the back, I already know where the back is I just need the front to be at the same height. If my front is sagging 2" Over stock then I need a 4" lift.
  5. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    Thinner leaves doesn't mean weaker....
    The only thing that will break a spring or cause it to sag is if it is overextended beyond "elastic limit". Like when you stuff the tire so hard that the spring goes inverted without a bumpstop to limit it's travel.
    The only way to make a spring soft, is to make it longer, narrower or use thinner leaves. Since the length and width of a sping are usually "non negotiable" dimensions.....using a lot more THIN leaves is the only option.
    As an example, my front springs use NINE leaves and flex like mad. :usaflag:
  6. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    9 leaves! Who made them, and are they stock length, stock dimensions? Do you remember what they cost? And of course do you have pics? I am very close to doing a 52 swap on the front of my 71 but just don't want to cut up a good blazer.
  7. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
    Yes, nine separate/thin leaves.
    Alcan makes the multi/thin spring paks.
