Front Springs
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Supergas, Jan 21, 2002.
  1. Supergas
    Supergas 1/2 ton status
    Oct 17, 2001
    161
    Texas Coast
    Does anybody know why someone would weld a plate at the rear shackle of the front springs to limit the rearward movement?? While installing the new Tuff Country 2" lift on my 71 Jimmy, I found a plate welded vertically at the rear of the front spring shackle that seemed to limit the travel of the spring. Neither my buddy or I could figure it out so we are going to remove it. Any comments or advice????
  2. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    Have the same thing on my GMC. Looking in a LMC catalog they also show it, as a bolt on. Mine is welded. My 70 GMC or <a target="_blank" href=http://communities.msn.com/jims70gmc>My 70 GMC</a>
  3. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Pretty sure that's a "stock" part. Mine's bolted in, and looks factory.
    Probably used to limit the shackle rotation so the spring didn't over-flex, or to keep the tire from moving too far back and hitting the wheelwell.
    Steve at ORD told me with his HD-Shackles I can remove that limiting plate....so I will. [​IMG]
    -Greg72
    '72 K5 Blazer - 427BB/TH350/NP205/6" Lift/35x12.50's
    <font color=blue>See it here: </font color=blue><a target="_blank" href=http://coloradok5.com/gallery/albun38>http://coloradok5.com/gallery/albun38</a>
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    That bracket was part of a recall. There is also a welded on plate on the front spring perch. Both are also only on the driver side. They were added so some steering control would be maintained if the front spring eye bolt broke. My guess is that the sway bar on the 73- also dose the same job.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  5. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    That is a factory part..... didn't really know why
    Like em big and topless
    You call THAT...a 4x4....LMAO?
  6. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Yup the 1969 Blazer was bustin front driverside eyebolts. We use to hang out at blazer-net.com , until it closed down, someone had an actual recall letter they scaned and posted for us to read. I have removed the rear plate, mine was bolted in and adjustable.
    <a target="_blank" href=http://coloradok5.com/gallery/Burt4x4>http://coloradok5.com/gallery/Burt4x4</a>
  7. Supergas
    Oct 17, 2001
    161
    Texas Coast
    Called ORD and ordered their extended HD shackles.. Then I cut the limiter out.. All is well...
    2 weeks &amp; Jimmy goes!!!
    350 TBI w/ 700R4
